lkuty
Jun 27, 2022Aspirant
GS716TP Using SNMP to reboot the device and/or power cycle a PoE port
Dear Community,
With a GS716TP switch (firmware 1.0.4.8), is there a way to reboot the device through SNMP ? In other words what is the OID which allows to do it if possible ?
As a bonus, are we able to power off/on a PoE port using SNMP ?
Thank in advance
Very few vendors have introduced private MIBs. Nothing in the standard MIB line AFAIK.
That's easy on industry standard MIBs, look here -> Howto enable/disable POE via SNMP - and simple port enable/disable as cherry on top
1 Reply
