Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
How to change IP Setting password
immapikatchu
Follower
In ProSAFE Plus Configuration Utility, what is the password that you input when you have selected a switch and enter in the IP Settings? How can you change this password?
Message 1 of 2
schumaku
Guru
Re: How to change IP Setting password
The previous configured password is typically what you are behind.
Keep in mind as a part of the continued security updates, the ProSAFE Plus Configuration Utility is obsolete, recently updated switches don't accept any configuration or password changes (unless this was explicitly allowed, permitting the old NSDP protocol access. Strictly focus on the Web UI available on all newer recent models for admin purposes as documented https://www.netgear.com/support/product/gs105ev2.aspx#docs (except of the obsolete ProSAFE Plus Configuration Utility).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 322 views
  • 0 kudos
  • 2 in conversation
Announcements
