VMHP
Sep 30, 2021Follower
JQuery issue ProSafe GS728TPv2 Switch
Hi
Recently we ran a Nessus scan for the switch above after updating firmware.
Nessus flagged a JQuery issue:
Description: According to the self-reported version in the script, the version of JQuery hosted on the remote web server is greater than or equal to 1.2 and prior to 3.5.0. It is, therefore, affected by multiple cross site scripting vulnerabilities. Note, the vulnerabilities referenced in this plugin have no security impact on PAN-OS, and/or the scenarios required for successful exploitation do not exist on devices running a PAN-OS release. Solution: Upgrade to JQuery version 3.5.0 or later.
Can anyone could tell me how to upgrade this or if it can be ignored please?
- JohnC_VNETGEAR Employee Retired
- MillwaarAspirant
Hi John,
I'm also having the same issue, would you mind dropping me a line?
Thanks.
- TonymnemonicAspirant
I am getting a similar vulnerability with AlienVault. jQuery is vulnerable to Cross-site Scripting (XSS) attacks. Is there a way to update jQuery?
- JDGTAspirant
- JDGTAspirant
Hello,
Looking for an update to this issue. Is there an ETA for a patch release to address the JQuery vulnerability?
- lr-ssbAspirant
I am having this same issue. Nessus detects jquery 1.6.2 installed on my Netgear switch
- chpcAspirant
We could also use an update, our vulnerability scan is showing:
jQuery End of Life (EOL) Detection (Linux) (OID: 1.3.6.1.4.1.25623.1.0.117149) Version used: 2021-06-11T09:02:34Z
Solution:
Update jQuery on the remote host to a still supported version.
