sdfungi's avatar
sdfungi
MS510TXUP SFP+ LAG Issues
Anyone else having issues with any of the MS510 models, and SFP+ lag configurations?
I can create the LACP LAG just fine with no issues on copper, but SFP+ refuses to work.
I know the switches see the connection with the SFP+ LAG as STP will disable it if I intentionally create a loop.
The SFP+ ports function correctly if not configured in the LAG.
  • schumaku's avatar
    schumaku
    To start with, open a ticket with Netgear Support via https://my.netgear.com resp. https://www.netgear.com/support/contact.aspx - provide as much information as possible, and also attach the Tech Support file there (Maintenance -> Export -> HTTP or TFTP -> Tech Support).
    What happens exactly?
    Can't configure the LAG (which  mode et all)?
    LAG does not come up?
    No traffic on the LAG, even if only one link is active?
    Had briefly tested the LAG functionality on the two LAGs during early adopter testing for the MS510TXUP, and it was working fine based on my notes. Currently, only LAGs on copper port active in the set-up where we have eployed MS510TXUP, SFP+ used as dedicated 10G links so afraid, can't check.
    • sdfungi's avatar
      sdfungi
      LACP on SPF+ auto defaults to the 192.169.0.239 management ip address.  VLAN IP is not reachable.
      LACP on 10Gbe VLAN IP is reachable and responsive.
      Both LACP configs are identical expect for the ports being used.
      I planned on opening a support ticket just thought maybe someone else might have run intothe same issue,
ProSupport for Business
