Orbi WiFi 7 RBE973
Reply
VLAN Membership vs PVID
RBee
Tutor
Hi all,
I'm new to managed switches, and just had a quick question...
If I'm setting up multiple VLANs, I'm wondering what the difference is between the VLAN Membership settings (where you click on the ports, per VLAN, and assign either tagged, untagged, or no traffic to).. and the PVID value you assign to each port on another screen (can't remember the screen right now, it's not in front of me).
I couldn't get other VLANs other than the default to work until I assigned VLAN IDs as the PVID to the ports I wanted those to be on.
I guess I'm a little confused, because I can assign untagged traffic to every port for every VLAN on the membership page, and then choose certain PVIDs for each port. When would I ever not have these two settings as a 1:1 match?
For example, VLAN 1's membership has untagged traffic on every port, but then only have PVID 1 set to ports 1-4.
Or the reverse, PVID set to 1 for every port, but the VLAN membership for 1 to only have untagged traffic on ports 1-4.
I hope I'm being clear, and that this makes sense.
Any clarification would be appreciated.
(I tried searching for this before posting here)
Thanks.
Model: GS108T|ProSafe 8 ports gigabit smart switch
Message 1 of 4
Accepted Solutions
schumaku
Guru
Re: VLAN Membership vs PVID
The PVID is used for VLAN which is run untagged on the switch port - and does define the VLAN where the untagged switch incoming traffic is associated to.
Message 2 of 4
All Replies
schumaku
Guru
Message 2 of 4
RBee
Tutor
So, if I only have untagged traffic, is it ok to assign the PVIDs and the VLAN memberships 1:1?
ie. vlan 1 = ports 1-4 untagged, and PVID 1 for ports 1-4
     vlan 10 = ports 5-8 untagged, and PVID 10 for ports 5-8
     etc...
Message 3 of 4
schumaku
Guru
     etc...
Excellent example! Yes, this will assign incoming untagged packets (to the switch) to the VLAN 1 for ports 1-4, and the VLAN 10 for ports 5-8. This will set-up the two port set's like independent switches.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 24650 views
  • 5 kudos
  • 2 in conversation
Announcements
