Sluggs
Aug 26, 2019Follower
GS724TPv2 Daisy chain and SFP Type
1. Daisy chaining this POE switch in small office to another older netgear switch do i just use a straight through cable from say port 24 on one to port 24 on the other?
2. What type of reasonably priced RJ45 SFP can i use if required as it only has the two SFP ports? or if im daisy chaining would i need it? sorry bit of a novice
Model: GS724TPv2|24-Port Gigabit Ethernet PoE+ Smart Managed Pro Switch with 2 SFP Ports
Yes, you may just connect port 24 of one GS724Tv2 to port 24 of the other GS724Tv2 using straight-through cable.
For the SFP ports, the GS724Tv2 is compatible with AGM731F, AGM732F and AGM734. As reference kindly, read page 9 of the GS724Tv2 Data Sheet here.
About the price, you may inquire to any NETGEAR Authorized Resellers here.
Furthermore, if you will implement VLAN on your network witht he GS724Tv2 switches, kindly read the article below:
How do I setup a VLAN trunk link between two NETGEAR switches?
If your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
1 Reply
- DaneANETGEAR Employee Retired
Regards,DaneA
