Connect Solar Inverter to WiFi
I'm attempting to connect the Powerline 500 from a solar inverter (in garage) to my computer (in house's router/switch 100 feet away). No success. All three green lights are on at each location and I have taken the plug out and pressed the reset. What is needed to complete the connection?
Where is the main connection between the garage and the router?
Where does the solar inverter come in to the picture?
- sparrowlarryAspirantThanks for the quick response. As you can probably tell I'm a real know-nothing.I'm trying to get my iPad to connect using WiFi to my computer that is in the house. The inverter in the garage hooks up directly to the solar panel connection that is tied in to the main electric source in the garage. At the house, near my computer, I am attempting to connect using my iPad.Larry
If you are expecting the Powerline network to connect the house to the garage, then they have to be on the same mains circuit.
Talk of a Solar Inverter suggests that the garage has a separate power circuit that may not be connected to the house.
Netgear's powerline series is designed for conventional home electric wiring. I have no idea how it would fit in with anything slightly exotic.
My first move would be to check that the powerline stuff works when it is all together in the same room. That will confirm that you have got it properly configured. Then you can move the "mobile" plug to different locations to see how it goes.
When it comes to wifi, what is the source of the wifi?
Is the XAV5201v2 bundle one of those that comes with a wifi plug? Netgear sells various bundles of plugs. (Look at the mix in my signature!)
What's the maximum distance I can be between my router and the hookup of the solar inverter?
I now have a Netgear AC1200 Dual Band WiFi Range Extender and it gets a strong signal.
I am attempting to connect wirelessly from a room in my home to a solar panel inverter in my garage. Any thoughts?
Larry
sparrowlarry wrote:
Any thoughts?Plenty, but I have offered them already and cannot suggest anything more until we have some answers to the questions about how this solar inverter works and how it connects to your main loops.
