RageFerret's avatar
RageFerret
PLP1200 Dropping LAN & Internet Connection
Bought these about 3 weeks ago to replace my reliable but ageing and a little slow Western Digital Livewire Powerline Hubs (200 Mpbs). Never had any trouble with the WD Livewires, just wanted something fast these days to keep up with fibre internet which was being bottlenecked by the Livewire’s for my upstairs PC’s.
The problem is that every now and then the PLP1200 devices cause the internet connection (and therefore LAN connection) to downstairs to be dropped.
My setup is 50Mb fibre connection downstairs with Ethernet cabling (Cat 6) through to PLP1200 socket to upstairs PLP1200 then Ethernet again to my main PC and NAS via a Netgear 1Gb switch. Measuring with “Tamos Throughput Tester 1.0 Build 28” from my upstairs PC to one downstairs, with the Livewires I used to get around 30-45 Mbps but with the new PLP1200’s I am now getting around 90 Mpbs which is a nice increase (when it’s working).
PC-to-PC LAN testing software here:
http://www.tamos.com/products/throughput-test/)
When the connection is dropped, if I look at the PLP1200 lights all three are lit green yet my LAN card reports ‘No Internet Connection’ and similarly my downstairs machines are gone from the Network browser. I have two Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controllers on my ASUS motherboard and I have tried using both to eliminate a fault in the one of the cards but they are seem to be fine. Like I said earlier, when I was using the WD Livewire’s I never had any such issue, its only started happening when I installed the new Netgear devices and retired the Livewire’s.
I have discovered I can force a fix for the problem by turning the PLP1200’s off and on again. Alternatively a slightly quicker solution is to open the Network Adapter settings then disable the adaptor currently being used, give it a minute, then re-enable the adapter and it then seems to restore the LAN connection through the PLP1200’s.
A pattern I have noticed is that I can play something like Mechwarrior Online for an hour or two and the LAN connection doesn’t seem to drop. Similarly, if I do an iMac Time Machine backup from the wife’s machine that will happily complete over an hour or two (10’s of GB )after going through the steps of: wireless -> wifi/router -> ethernet -> PLP1200 -> PLP1200 -> 1Gb switch -> NAS. However, if I do something a lot less network intensive such as browsing the internet via Chrome or Firefox for a short space of time (at a guess at least 10 minutes) I’ll suddenly get a web page error “No Internet Connection”. It’s almost like there isn’t enough network traffic bashing the PLP1200’s to keep the powerline connection open and they have dozed off – yet the lights don’t indicate they have gone into sleep mode or anything!
Anyone else getting similar issues?
I would assume there is some fault in the network traffic monitoring that is indeed putting the devices into a sleep mode incorrectly and similarly not indicating as such visually. I would hope a firmware update could resolve this – similarly some control/admin software to disable any ‘sleep’ mode might help too.
  • According to the PLP1200 installation guide, the device will go into power saving mode if it detects no activity on the Ethernet interface for 10 minutes. The thing is that the Power LED color should change to amber when this happens.
    I would suggest that you try two things:
    1. Try using a different Ethernet cables between your PC and the PLP1200, and your other PLP1200 and the router.
    2. Go into the Advanced settings for the Ethernet interfaces on your Asus and disable any power saving features.
    • RageFerret's avatar
      RageFerret
      Thanks for the suggestions Ether.
      I have tried swapping the cables already.
      At the moment Windows 10 is set to Maximum in the Power Settings so it doesn't enter sleep or hibernate anyway. I have however just changed the LAN adapter settings to un-check the "Allow the device to sleep..." option just to see if it will make any difference. I suspect it won't as the adapters were not causing any issue when used with the WD Livewire powerline adapters. Appreciate your reply though :-)
      Having had a look at other forum posts it looks like we are waiting on Netgear updating their general Powerline adapter configuration software to make it compatible with the PLP1200's. Hopefully that will let us disable the sleep mode on the devices completely.
        RageFerret
        Just to follow up on the last tests, unfortunately disabling sleep mode on the network adapters did not work as I've still experienced the loss of LAN/Internet a couple of times since then. I've also tried downloading the latest Netgear Genie v2.4.16 software from which you can see the PLP1200 devices in the network map (tip: click the far left icon at the top right of the view to show powerline adapters) but there is no option to configure them except for changing the encryption password between them.
        Still hoping Netgear will issue a firmware update or something for this as it looks like some of their other adapters have similar issues judging by the forum posts.
