Brian1974's avatar
Brian1974
Follower
Mar 27, 2023
M4300 52G and M4300-24X24F
Hi There,
I have 2 Core x M4300-24X24F ProSAFE 24-port 10GBASE-T and 24-port 10G SFP+ stacked together on ports 45-48
I then have;
1 x Edge1 M4300-52G ProSAFE 48-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ connected to ports 1:1 & 2:1 LAG
1 x Edge2 M4300-52G ProSAFE 48-port 1G and 2-port 10GBASE-T and 2-port 10G SFP+ connected to ports 1:2 & 2:2 LAG
These switches are being used for KVM over IP using Adder KVMs
Multicasting is enabled on all switches which is required for the KVM to be used in several receivers at once - one to many video/audio USB,
KVM has been assigned to VLAN 172
On the Core Stack
IGMP Snooping Configuration
Everything is set to Enable except validate header (should this be on?)
Vlan IDs enabled  for IGMP snooping (1,172)
Multicast Control Frame Count 339768
Interface Configuration
Admin Mode:Disabled on all ports and lags
Fast Leave -enabled
Proxy Querier - enabled
Fast Leave Operational Mode - disable
IGMP Snooping VLAN Configuration
Admin Mode:Enable
Fast Leave:Enable
Membership Interval
Maximum Response Time
Multicast Router Expiry Time
Report Suppression:Disabled
Proxy Querier:Enabled
Report Flood Mode:Enabled
Exclude Mrouter Interface Mode:Enabled
IGMP Plus Mode:Enabled
Querier Configuration
Querier Admin Mode:enabled
Snooping Querier Address:169.254.100.100
IGMP Version:2
Query Interval(secs)60
Querier Expiry Interval(secs)180
IGMP Snooping Querier VLAN Configuration
VLAN ID: 1,172
Querier Election Participate Mode:enable
Querier VLAN Address:0.0.0.0
Operational State:Querier
Operational Version:2
Operational Max Response Time:120
Multicast Router Configuration:Not set up on anything
Multicast Router VLAN Configuration:Not set up on anything
MLD Snooping Configuration :enabled but not setup or configured
On the Edge switches Edge 1
Multicast Control Frame Count 5701
Fast Leave -enabled
Fast Leave Operational Mode -enable on all ports that are connected
Admin Mode:Enable
Fast Leave:Enable
Membership Interval
Multicast Router Configuration:Lag1 set as enable, all others disable
Snooping Querier Address:169.254.100.102
IGMP Version:2
VLAN ID: 1,172
Last Querier Address 169.254.100.100
Operational State:NoN-Querier
Edge 2 setup the same as Edge 1 with a Snooping Querier Address:1169.254.100.102
Devices on Edge 1 work perfectly fine with IGMP multicast allowing multiple streams of KVM audio and video to several receivers.
However Any Device on Edge 2 cannot correctly receive multicast information from edge 1 and vice versa, they seem to receive a multicast IP in the adder management, but will not pass video streams/traffic.
What am I missing or whats configured incorrectly?
Any help appreciated
Thanks
No RepliesBe the first to reply
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
ProSupport for Business
