RandyL's avatar
RandyL
NETGEAR Expert
Dec 12, 2019
NETGEAR IGMP Plus Whitepaper
What is NETGEAR IGMP Plus™?
NETGEAR’s AV Line M4250, M4300 and M4500 fully-managed switches provide a unique feature called IGMP Plus. This feature greatly simplifies system architectures by enabling the same well-known IGMP techniques across the entire AV over IP (AVoIP) network. In a nutshell, IGMP Plus is an enhanced implementation for automatic multicast across a Layer 2 multicast network.
Why is NETGEAR IGMP Plus Important?
NETGEAR IGMP Plus provides ProAV network engineers with an effortless implementation of a Layer 2 multicast network. With other switching vendors, the process of configuring a ProAV multicast VLAN requires many IGMP commands to be entered via the command line which introduces the possibility of user error due to the complexity
Download the whitepaper explaining the new IGMP Plus feature on the M4250, M4300 and M4500 switches.
Click here to download the IGMP Plus whitepaper .
  • Read the whitepaper, thanks - but what is the single command to enable IGMP Plus?
    • RandyL's avatar
      RandyL
      NETGEAR Expert
      Hi c_b,
      The M4300 and M4500 has the IGMP-plus commands in the latest firmware release. Please keep in mind that the single (CLI) command is to configure IGMP and the other IGMP options on the specified configured VLAN.
      igmp-plus<vlan-id> This command enables IGMP enhancements for the specified VLAN to support audio and video devices in an SDVoE environment.
      Format     igmp-plus<vlan-id>
                      no igmp-plus<vlan-id>
      Default     igmp-plus 1
      Mode       Global Config
      Thanks,
      Randy
  • Great whitepaper but I would love to know where the information is based on that you need 14 steps to configure IGMP in a GigaCore 26i as this is enabled by deafault?
    • schumaku's avatar
      schumaku
      It's not about "just2 enabling IGMP. There is a Cisco-like sample config shown above the table. hard to imagine this is already there in place.
      • CrazyGoose's avatar
        CrazyGoose
        By default, in every group/vlan already available in the switches (20 are pre-made for you) the IGMP querier and snooping are enabled by default. The global settings have IGMP unknown flooding enabled so all you would have to do is disable this or disable it in a group which will not take 14 commands hence why I would love to know where that number is comming from?
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
ProSupport for Business
