fallais
Jul 24, 2024Follower
AP keeps deconnecting clients and high retry rates
Hello,
We have bought and installed 5 AP in our big house (for our company), made of strong walls.
- WAX214v2 (AX1800) (dinner room 1 floor 0)
- WAX214 (AX1800) (kitchen)
- WAX214 (AX1800) (bedroom 1)
- WAX610Y (AX1800) (outside)
- WAX214v2 (AX1800) (dinner room 2 floor 1)
We are facing many disconnections from the AP, experiencing very bad Wifi performances, and I can see a high rate of retries on clients.
What we have done so far to improve the situation :
- Tune the channels to totally erase the overlapping
- Enable fast roaming
- Separate 2.4ghz and 5ghz
- Reduce power when it is needed
Everything looks better know when looking at with "LinSSID" and "wavemon" tools.
But we are still facing the same issues.
Question 1 : what can we do next please to improve the situation ? (I can also share some logs if needed)
Question 2 : why is there less available 5ghz channels in WAX214v1 compared to v2 ?
Thanks a lot.
1 Reply
Bonjour fallais
Because of the WAX214(v1) was never certified for the DFS channels.
When using HT80 channels, all four available 5 GHz channels are in use, so you don't have any choice.
-Kurt.
