dacarson
Jan 27, 2019Aspirant
Building Nodejs on ReadyNas
After many attempts, I was finally able to build Node on my ReadyNas.
For those who are trying to do this, I basically followed instructions here:
http://elsmorian.com/post/23474168753/nodejs-on-raspberry-pi
Rather than the old Node version mentioned in the URL above, I checked out a newer version:
$ git checkout v10.15.0
Doing a little research, I found that the ReadyNas that I have, has a ARM Cortex A15. This CPU has an ARMv7-A architecture, so I entered the following lines into the shell:
$ export CCFLAGS='-march=armv7-a' $ export CXXFLAGS='-march=armv7-a'
I tried building everything and found that I had to comment out one line, which I think impacts debugging. In the file:
deps/v8/src/base/platform/platform-posix.cc
There are these lines:
void OS::DebugBreak() {
#if V8_HOST_ARCH_ARM
//asm("bkpt 0");
#elif V8_HOST_ARCH_ARM64
I had to add the '//' to the asm line
Then kicking off the build:
$ ./configure $ make $ make install
The "make" took a long time, aka almost 2 hours. After it was built and installed, it was all there:
root@ReadyNas:~# node -v
v10.15.0
root@ReadyNas:~# npm -v
6.4.1
- JohnCM_SNETGEAR Employee Retired
Hi dacarson,
Welcome to the Community!
Thank you for sharing this information. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
- DModTutor
Can you please go into greater details how you were able to get this to work?
I've been looking all over trying to get this set up and you're the first person I've seen who was sucessfull.
Thank you so much in advance
- dacarsonAspirant
I can help you out with getting it to compile. Can you tell me which part of the instructions I point to are not working?
- DModTutor
Are you compiling it on the NAS or on your computer then transfering it over to install?
I was having trouble typing out
so I just downloaded the files onto my computer. I entered
like you said and commented out the line in the code. When trying to run make I'm getting this error but I'm running make on my computer.
node/node-master/out/Release/obj.target/icuucx/deps/icu-small/source/common/uniset_props.o.d.raw -march=armv7-a -c ../deps/icu-small/source/common/uniset_props.cpp:1:0: error: bad value (armv7-a) for -march= switch // © 2016 and later: Unicode, Inc. and others. ^ tools/icu/icuucx.target.mk:290: recipe for target '/home/m/node/node-master/out/Release/obj.target/icuucx/deps/icu-small/source/common/uniset_props.o' failed make[1]: *** [/home/m/node/node-master/out/Release/obj.target/icuucx/deps/icu-small/source/common/uniset_props.o] Error 1 Makefile:99: recipe for target 'node' failed make: *** [node] Error 2
I'm logged in as root through ssh. What steps do I now take? Is there a reason why not installing it through apt instead?
