Ronmoul's avatar
Ronmoul
Compatibility firmware 6.6.1 and Logitech Media Server NT 7.9.0.b7dfc80-nt1 for armel
Hi, i would like to know if the last version of the Logitech Media Server NT 7.9.0.b7dfc80-nt1 for armel is compatible with the firmware 6.6.1. for a ReadyNAS 104.
Thanks a lot
Ronald
  • Hello Ronmoul,
    Have you checked the available apps?
    I tried on our own ARM based OS6 and found one from the available apps, that is 7.9.0-1477086729-nt1. I was able to install and it launched with username and password prompt.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello Ronmoul,
    It still uses the same info about apps. So it should be working with it. Please check the post about the 6.6.1 from this link.
    • Ronmoul's avatar
      Ronmoul
      Hello JennC!
      Thank's a lot for your response.
      I had already read the information in the link you have provided. I was just confuse because in these pages there is a list of incompatible applications, like Logitech Media Server NT 7.9.0.b7dfc80-nt1 and at the same time there is a link to download the application (?)
      Anyway, i have upgraded my Nas Rn104 with the firmware 6.6.1 and now the Logitech Media Server is not working at all ! too bad ...
      Now I will wait for a fix for the Logitech Media Server
      thank you
      • JennC's avatar
        JennC
        Hello Ronmoul,
ProSupport for Business
