eton
Nov 16, 2012Luminary
RSS for Transmission add-on?
Is there some possibility to get RSS functionality with the Transmission add-on?
- etonLuminaryThanks JarnoG, looks promising!
To configure automatic rename the file /etc/automatic.conf-sample to /etc/automatic.conf and edit the contents as needed.
Here is one of the help threads:
viewtopic.php?f=36&t=61041 - sgirardTutorHi Eton,
I am currently using Flexget. It takes a little bit of time to get it configured for exactly what you want it to do, but there are a lot examples on their website. You can find the ReadyNas installation instructions at http://tinyurl.com/3lms32o. Their Cookbook has tons of useful information.
Best of Luck
Shawn - teachingsAspirantHi,
I would like to use Transmission on port 80, not on port 9091 (because of university's proxy for example...).
How can I do this ? - Mr_BGuideTransmission doesn't use port9091, it's listening on that port for connections to the command interface. The actuall torrent trafic takes pace on a range of ports defined in the settings.json
If you want to change the ports, for transfers, or controll interface, it's a matter of changing those settings in the .json, just turn transmission OFF first. (In Frontview)
B!
