MALCOLM1265's avatar
Jan 08, 2022
AC1750, Model R6400v2
AC1750, Model R6400v2 I just recently updated to the recent firmware and now the nighthawk app cannot find my router nor the IP address work to login. Please help.
Thanks
  • plemans's avatar
    What modem/gateway is the router connected to?
    Is it working?
    what firmware version did you install?
    • MALCOLM1265's avatar
      MALCOLM1265
      Guide
      My modem is through cable provider Spectrum Model EN2251 is on the modem. The latest firmware 1.0.4.122 we did it yesterday. The internet is working I just cannot login to the IP address 192.168.1.1 as an admin to monitor my devices. The nighthawk app states it cannot find my router. So I reboot, reset everything and nothing is working. I just wish I never updated that darn firmware.
      • plemans's avatar
        Have you checked to see if its at that gateway address?
        Pull up a command prompt in windows and type ipconfig
        That'll tell you what the gateway address is.
