× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
C6300 – Unable to login into Modem
justinyeskey
Although my C6300 – AC1750 WiFi Cable Modem Router is working and my connection speed is great I'm unable to login to my modem's menu/settings page. I have tried http://routerlogin.net which just routes me to Netgear's website and also http://192.168.0.1 which I confirmed is correct by checking via "ipconfig" in command prompt. I recently added a Verizon Network Extender and need to access my Netgear settings to make changes.  Please advise how else I can access the modem/router menu page or what may be causing me not to be able to access using the exact address in my browser?
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 8
Guru
Re: C6300 – Unable to login into Modem
Try a different browser.
Also try going to 192.168.100.1
Message 2 of 8
justinyeskey
Thanks for your help.  Unfortunately I just tried and neither of those suggestions worked.
Message 3 of 8
Guru
What error are you getting?
whats actually happening when you do that?
have you tried hardwired into the router?
Message 4 of 8
justinyeskey
Yes I am hardwired to my router. See screenshots of the error message I am getting.image.pngimage.png
Message 5 of 8
justinyeskey
Noticed that my screenshots aren't showing. Please see attached for the error message.
Message 6 of 8
justinyeskey
Should I try doing a full reset of my router and then see if I can login to the router via the Default Gateway IP address 192.168.0.1?
Message 7 of 8
Guru
You can try a factory reset?
Are you able to ping the IP address?
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1542 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
