× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Frequent reset required on R6300 to restore wifi
LeShek
Firmware: V1.0.2.78_1.0.58
I have to frequently reset R6300 to restore wifi.  Only soft reset is required, just power off and on.
Hardwired connectivity is nor affected.
Sometimes it is required everyday, sometimes it is okay for a week or so.
Worked fine for a long time (years) and the problem started a few months ago.
I am using only 2.4Ghz.
Any suggestions how to fix it?
Model: R6300|Dual Band 11ac WiFi Router R6300
Message 1 of 4
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Frequent reset required on R6300 to restore wifi
Hi @LeShek,
You are welcome.
1. You can try the NETGEAR Genie WiFi Analyzer for Android. There are more powerful ones for PC like inSSIDer that you can look in to.
2. A factory reset clears the device's memory that may sometimes get rid of recurring issues. Yes, you can save the router's configuration and restore it. You can check the links below.
http://kb.netgear.com/app/answers/detail/a_id/24231
http://kb.netgear.com/24232/
Dexter
Community Team
Message 4 of 4
All Replies
DexterJB
NETGEAR Moderator
Hi @LeShek,
1. Have you tried changing the wireless channel? Try using a WiFi analyzer app/program to check for the best channel.
2. Are all your wireless devices affected?
3. Have you tried doing a factory reset for the router?
Dexter
Community Team
Message 2 of 4
LeShek
@DexterJB, hi thank you for jumping in.
Tried it many times on 5GHz.  The 2.4 is on Auto.  I have not tried WiFi analyzer; economical reccomendation of one woyld be apprecitated.
Yes, it goes solid blind for all wifi devices.
Resisting to do that, as it will require reconfiguring all the settings for all users and shares and ports.
Why would that help?  What would it clear that soft reset does not?
Is there a way to save and then restore user configurtion?
Message 3 of 4
DexterJB
NETGEAR Moderator
Hi @LeShek,
You are welcome.
Dexter
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3413 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
