simard's avatar
simard
I need a router that shows data usage per connected device
I am in need of a router that logs each device IP connected and the data used per connection per device. I need to see how much bandwidth each device is using each hour and each day. I only need standard 2.4 GHz WiFi. I currently have an n750 but it doesn't log per device only per the router itself. I really would like a router that has detachable antennas so I can hook up to my amplifier and ceiling mounted antennas. I can modify if I have no choice and add antenna connections but the ability to see the data usage per IP address is the critical feature I need. Thank you.
  • You won't find it at NETGEAR. They do not offer a router with firmware that tracks bandwidth or volume per device.
  • plemans's avatar
    What N750 do you have?
    Some have 3rd party options (ddwrt/tomato) that offer data tracking.
    but it voids your warranty and can put you at a risk for bricking your device.
    Just an option to try before buying something
      • plemans's avatar
        You won't find a stock netgear consumer model that will.
        Again, what n750 model do you have?
