Michael_O
Jan 01, 2017Follower
Inconsistent USB Storage Connection
I have two Macs that I want to set up with automatic Time Machine backups over WiFi. I used to do this with an Apple Time Capsule, no problem.
I have two hard drives in an IcyRAID enlcosure (MB662U3-2S R1) that I want to use. I have been able to connect the computers to these drives using the provided instructions with the router manual.
However, the drives keep disappearing off the network and I have to go in and physically disconnect the cable and reconnect it to get them to come back.
When I do this, the drive letter seem to changing at random, so I have to connect to a different drive every time. (i.e. one time it's G, the time it'll be F, the next time it'll be P)
As if this wasn't frustrating enough, the router dashboard sees 4 drives, even though there are only 3 on the network - one built in to the router (200 MB) and the two in my IcyRAID enclosure (4TB and 2TB). 2 of these drives share the same letter every time and, you guessed it, they're the 4TB and the 200MB drives. When I try to connect to the 4TB drive, I can now only get the 200MB one, so even though the router knows it's there, I can't connect to it.
This is the case whether I am using AFP or SMB to connect.
So, three questions.
1 - How can I get the router to differentiate between the drives properly?
2 - How can I get the drive/share name to stop changing?
3 - How can I keep the drives/shares available all the time?
Any help would be much appreciated.
Hi Michael_O,
I believe the issue of the changing drive names can be addressed if there is a stable connection between the router and the enclosure. Unfortunately, there is no way for you to assign a volume name to a specific drive. I would also like to confirm the following information:
1. What is the model number and firmware version of your NETGEAR device?
2. Is the 200 MB storage that is being detected referring to the internal flash memory ? Or is it another storage device?
3. Have you tried resetting the router?
4. Have you tried re-flashing the firmware?
5. Is the enclosure connected to the USB 2.0 or 3.0? Have you tried swapping?
6. Is the connection stable if the enclosure is connected straight to a computer?
7. Are the drives set to JBOD configuration?
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi Michael_O,
Dexter
Community Team
