- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New router can't connect to internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I got this new router and I want to replace my old one. I connected the cables I was using for my old router, and connected to this new one(this includes 1 white ethernet cable from the wall to port4, another yellow ethernet cable going to powerline adapter for ethernet extension to port 1, another yellow ethernet cable for ont broadband, and coax. But only the port connected to the powerline adapter was blinking).
Since this router has only two ethernet ports, and I need the powerline extension, I tried both ethernet cables but neither gave me internet connection.
The wifi led got lit, and I could connect to it's wifi but it didn't have internet access. The downstream led was blinking. Also the internet led never turned on once. What should I do?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] It's an att uverse 5628ac. [...]
"5268AC"? That (almost) answers one of the many questions. What
about the others? Look for "?".
> [...] I got a 2 month used router from someone I know, so I'm trying
> to switch to that one.
I doubt that it's suitable. As I understand it, the co-ax connector
on an 5268AC is used to connect to some old-style client devices. The
co-ax connector on a C6250 is used to connect to the (cable-TV) ISP.
Not even similar.
Also, because you're not using the "DSL Broadband" port, the cable to
the "ONT Broadband" port (from your "the wall" I'd guess?) must be your
connection to your ISP, and a C6250 has no Ethernet WAN/Internet port,
making it useless as a replacement for a 5268AC.
Nice try, but you seem to be in a square-peg/round-hole situation.
You want a friend with a plain-old router (with an Ethernet WAN/Internet
port), not a cable modem+router (with a co-ax WAN/Internet port).
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New router can't connect to internet
> [...] I got this new router and I want to replace my old one. [...]
Why? What was your "my old one"? Maker? Model number? Who/what is
your ISP?
> [...] this includes 1 white ethernet cable from the wall to port4,
"the wall"? What's behind your "the wall"? What's "port4"?
> [...] another yellow ethernet cable for ont broadband, and coax. [...]
"ont"? "coax" from what to what? Your "(unspecified) "my old one"
had a co-ax connection?
Your description seems to include three Ethernet cables. At least
one of us is confused.
> Model: C6250|AC1600 WiFi Cable Modem Router
If I had been using more than two Ethernet ports with my
(unspecified) "old one", then I might have chosen a different model with
more Ethernet ports.
> What should I do?
Start with a less confused/confusing problem description?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not even similar.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] Did I understand it right?
It seems so.
There could still be some fine-print requirements (about which I know
nothing) involving use of a user-supplied router with your ATT U-verse
service, but a cable modem+router has no chance.
