Dharmajeet87's avatar
Dharmajeet87
Nighthawk router firmware update
My nighthawk router is blocking Hulu streaming after firmware upgrade.Please help.
  • michaelkenward's avatar
    michaelkenward
    There's not enough there to go on.
    What Netgear router is this? What firmware have you applied?
    What do you mean by "blocking"? What are the symptoms?
    If you can't fix the issue, the first move is to reset the router and set it up from scratch.
    • Dharmajeet87's avatar
      Dharmajeet87
      Router Model: R6400v2
      Firmware Version: V1.0.4.122_10.0.95
      I have tried to restore factory settings but no use.
      Hulu is not working on any devices. Hulu error code: P-DEV302
      I am able to login to Hulu but not able to watch any content. The above error is displayed after clicking on a content.
      • plemans's avatar
        I get what router you have. What modem/gateway is that router connected to?
  • plemans's avatar
    Are you using armor or parental controls?
    What modem/gateway is it connected to?
    What error do you get?
    Is it blocking it on all devices, just one?
      Dharmajeet87
      Hi Sir,
      A1: I am not using armor or parental control.
      A2:It is R6400 v2
      A3: I am getting P- DEV313 Hulu error code while streaming any content
      A4: Yes it is blocking all the devices.
      • plemans's avatar
        1. what modem/gateway is the router connected to?
        2. what firmware did you install?
        3. did you try a factory reset on the router? Maybe an old setting is causing issues.
  • Router Model: R6400v2
