Orbi WiFi 7 RBE973
Unable to Enable Access Point Mode
Habibulalam
Tutor
Hello sir,
This is Md. Habibul Alam, from Dhaka, Bangladesh. I'm using Netgar R6220 Router. and i con't Enable Access Point Mode to make wireless Bridge at my Home.
Netgear R622 is my main router, and i want to connect "Tenda F303" as wirless network rang extender. But i can't Enable Access Point Mode. please help me by instructing to make an netwark bridge using WDS
Thanks for your time and consideration
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 1 of 5
Accepted Solutions
TheEther
Guru
Re: Unable to Enable Access Point Mode
In Netgear's terminology, Access Point mode is not the same as a wireless bridge.
Access Point mode: Requires a wired connection to the main router.  Provides Wi-Fi and wired access to clients.
Wireless bridge: Uses a wireless connection to the main router.  Provides wired access to clients.  Wi-Fi clients are NOT supported.
The R6220 can be used as an Access Point.  It is enabled in ADVANCED > Advanced Setup > Wireless AP.  The R6220 cannot be used as a wireless bridge.
Message 2 of 5
All Replies
TheEther
Guru
Message 2 of 5
Habibulalam
Tutor
is their any way to connect between netgear r6220 and tenda f303 wirlessly?
Message 3 of 5
TheEther
Guru
Already answered here.
Message 4 of 5
Habibulalam
Tutor
Thank you somuch, I did it successfull.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4703 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
