× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
rename Attached Devices
niekn
When I look under "Attached Devices" in the router I see a lot of device names which have a meaningless names for me
like android-2637812647862. By checking the MAC adres or the IP adress at that devices i can find out which devices it is.
But it would be nice that i can change the name of these devices in my router, is that possible ???
i already installed the app "genie" on my smartphone. And there i can changed the names, but the router wil not take over these names.
the router which i have is: WNDR4500 – N900
Model: CENTRIA (WNDR4700/4720)|Media Storage Router
Message 1 of 8
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: rename Attached Devices
That's true. The unit has been EOL for a while.
Message 8 of 8
All Replies
ElaineM
Welcome to the community, @niekn
If you see Access Control feature under Security, you may change the device name there by turning on the feature.
Or see Address Reservation feature.
Message 2 of 8
niekn
Hi ElaineM
i cannot changed the device names at Access control, which feature should i turn on?
I turned on Acces control , so i can block some devices
Ad Address reservation , i can add a device name, but this name are not shown in the lised of connected devices.
Need more help
Message 3 of 8
ElaineM
When you turn on Access Control and select the device, do you see Edit to be available for you to edit the device name?
Message 4 of 8
niekn
when i do that , i do not get  the "edit" function , image is in dutch. The name ARK and blackhawk, are names of PC's (device name is used from the device itself)that is working
but the android devices and "--" devices i cannot rename.
Message 5 of 8
ElaineM
Oh, do you have the latest firmware installed?
If you already have and still unable to see Edit then it cannot be changed.
Message 6 of 8
niekn
yes, i already installed latest firmware version. I think no update will be done anymore for this device
but thanks for support
Message 7 of 8
ElaineM
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 34831 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
