WesL01's avatar
WesL01
Port forwarding two things through the same port
I am trying to port forward two things through the same port, I add one and it works fine. but when I try and add the second to the same port it says that that one is already in use.... The port is 44158 and I am using the Netgear Nighthawk MR60 Mesh Network system.
    • schumaku's avatar
      schumaku
      Assume you talk of some ISP or third party NAT routers (probably on some Netgear NAT router supporting ReadyShare according to the screenshot), not on the subject switches.
      Simple: You can port forwarding one port always to a single device or LAN IP.
      Consult with this "Miners" application support or community for having multiple servers active at the same time.
      • WesL01's avatar
        WesL01
        Both Servers are ran through a Netgear GS308E "Smart Switch", so I was told to post my question here. When I plug in my LAN ip it says that cant cant be a LAN IP.
ProSupport for Business
