- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Presales Q: GS108T vs GS308T
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to work out the main differences between the current GS108T and GS308T models. Both are similarly priced and appear to have similar functionality. Are they aimed at different market segments or one a more recent model?
Looking for a small managed switch in a medium complex SOHO environment.
Any pointers appreciated
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Welcome to the community! 🙂
Here is the main difference. The GS108T can be powered on using two methods. First is by using the power adapter that comes with its package contents. Secondly, by using Port 1 connected to a PSE (Power Sourcing Equipment) such as a PoE switch. Port 1 of the GS108T is a PoE PD (Powered Device) port that can receive PoE power so that you can you use the switch without a power adapter. The latest GS108T switch model is the GS108Tv3 (v = version). As reference, kindly read pages 20, 23 and 38 of the GS108Tv3 Hardware Installation Guide here.
With the GS308T, it can only be powered on using its power adapter that comes with its package contents.
For more information about the GS308T and GS108Tv3 switches, kindly access the links below:
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
DaneA
