daboywonder2002's avatar
Jun 23, 2021
Desktop says turn on wirelelss capability
Hello I need help. My wifi adapter is failing. Right now i'm on network connections and the Wifi adapter shows but its not connected. You hit diagnose and it says turn on wireless capability. But it's a desktop. And it doesn't have a built in wifi. That's why i had to buy the adapter. There is no switch on the front or sie of the pc. Or fn keys to allow wireless capability. Wireless capability is turned off. EVen at the bottom right where it shows network and internet settings and under it you see wifi, airplane mode. right click on wifi and hit settings. Click on to turn wifi. But at the bottom right it still says wifi turned off.
Already tried uninstalling and reinstalling and trying different usb ports.
  • michaelkenward's avatar
    michaelkenward
    Windows? Mac? OS Version
    Is that (top right here) Network and Internet Settings? Is there anything there in Show Available Networks?
    Have you run the "Troubleshoot Problems" wizard?
    What do you see here:
    Control Panel\Network and Internet\Network Connections
        michaelkenward
        It may be some time before the images land. To ensure that you aren't posting anything naughty, a Netgear moderator has to approve the pictures.
        You can attach images to messages without any delay. (Look for the Browse button at the bottom of the text window.)
