Supamarioana
Dec 08, 2017Aspirant
unexpected network error with WNA1100 wlan USB adapter
Hello there,
I got the following problem and I hope somebody here can help me out: I receive an 0x8007003B (unexpected network error) whenever I try to transfer several folders containing rather small files (JPEGs, mp3s, docs) from my PC to a WesternDigital EX2 Ultra Network storage. It works for a few seconds, but then the transfer rate suddenly drops to zero an I cannot access any webpage anymore. WLAN traffic of the computer comes to a complete halt for half a minute or so until the Windows message with the error code pops up.
Except for this problem, web traffic runs fine. I can download big files and even play coop games with a friend. There's a bit lag sometimes but I never thought of it as a big problem.
This is my setup:
WD EX2 Ultra <--(LAN)--> Fritz!Box 7362 SL <--(WLAN)--> PC (Windows 10) with WNA1100 wlan USB adapter (driver v2.2.0.1 from Netgear support page)
It took a while, but I could isolate the WNA1100 as the problem, because there is no problem when I connect the PC by LAN to the Fritz!Box. Also I've got a notebook from which I can transfer files to the WD EX2 Ultra without problem. But if I deactive its internal WLAN adapter and use the WNA1100, then I get the same problem as with my PC.
So I would be thankful for any ideas. :-)
- JamesGLNETGEAR Employee Retired
Hi Supamarioana,
Try to uninstall and reinstall the driver of WNA1100.
- SupamarioanaAspirantHello JamesGL,
I reinstalled the "GENIE" software including the driver, but no change.
As I described in my opening post, I also installed the adapter on my notebook last week for the first time ever and it showed the same symptoms. But there is no problem when I use the notebook's internal WLAN. So I don't think there is a general problem with WLAN connections.- JamesGLNETGEAR Employee Retired
Hi Supamarioana,
Have you tried the standalone version of the driver?
