Reply
Add POE to non-POE Switch
JNew99
Follower
Last year, I purchased a JGS524 24 port unmanaged switch.  This year, I need to add POE access points (thinking of Ubiquiti) to extend our wifi signal.  I was going to buy either a 4 port or 8 port POE Switch
Can I connect the new POE switch to my existing unmanaged switch?  Any other suggestions on either switch or wifi?
Thanks in advance.
Model: JGS524F|ProSafe 24 port gigabit switch with 2 SFP slots
Message 1 of 2
Accepted Solutions
schumaku
Guru
Re: Add POE to non-POE Switch
Any Netgear unmanaged or Smart Managed Pro PoE/PoE+/PoE++ unit.
I would go for a Insight or Remote Cloud Managed switch in combination with some Netgear One-touch wireless connectivity & visibility with Insight Managed Access Points - Insight and Local ...  access points like WC505/WAC540/WAX610 if indoor for example.
Without knowing anything more - hard to help.
Message 2 of 2
All Replies
schumaku
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 693 views
  • 0 kudos
  • 2 in conversation
Announcements
