jtnn60's avatar
jtnn60
Cannot perform a remote shutdown of a ReadyNAS using shell script and CURL
Based on various previous forum posts, I have developed the following shell script to use CURL to shutdown my ReadyNAS.  I read about the need to add a csrfpId token due to a previous security fix to the firmware.  Anyone know why I still get a "Forbidden: You don't have permission to access /dbbroker on this server" error?
Firmware: 6.10.3
ReadyNAS RN212
#!/bin/sh
host=192.168.0.11
username=admin
password="xxxxxx"
token=$(curl -sS -u $username:$password  http://$host/admin/csrf.html | grep -oP '"csrfpId", "\K[^"]+')
curl -sS -v --header "X-CSRFToken: $token" -u $username:$password  -k "http://$host/dbbroker" -H "Content-Type: application/x-www-form-urlencoded;" -H "X-Requested-With: XMLHttpRequest" --data "<?xml version=\"1.0\" encoding=\"UTF-8\"?><xs:nml xmlns:xs=\"http://www.netgear.com/protocol/transaction/NMLSchema-0.9\" xmlns=\"urn:netgear:nas:readynasd\" src=\"dpv_1584484996000\" dst=\"nas\"><xs:transaction id=\"njl_id_1628\"><xs:custom id=\"njl_id_1628\" name=\"Halt\" resource-id=\"Shutdown\" resource-type=\"System\"><Shutdown halt=\"true\" fsck=\"false\"/></xs:custom></xs:transaction></xs:nml>"
The script, which has the verbose flag, provides the following output:
root@raspberrypi:/hassio/homeassistant# ./readynas_shutdown.sh
* Expire in 0 ms for 6 (transfer 0x13ca880)
*   Trying 192.168.0.11...
* TCP_NODELAY set
* Expire in 200 ms for 4 (transfer 0x13ca880)
* Connected to 192.168.0.11 (192.168.0.11) port 80 (#0)
* Server auth using Basic with user 'admin'
> POST /dbbroker HTTP/1.1
> Host: 192.168.0.11
> Authorization: Basic YWRtaW46JU44QlZqV3c1ZVVf
> User-Agent: curl/7.64.0
> Accept: */*
> X-CSRFToken: SqzNmy9s78lY3LydAw217jaeKxLW04zhFem0mVmEHI6jR5pwL08fDGZWQlZpO_X_0IeKtmZQ0pvv-xYiBRVE0X4B4kh9Mz3j3D3hWorJSmY=
> Content-Length: 376
* upload completely sent off: 376 out of 376 bytes
< HTTP/1.1 403 Forbidden
< Date: Tue, 17 Mar 2020 23:05:48 GMT
< Server: Apache
< Access-Control-Allow-Headers: csrfpid, x-requested-with
< WWW-Authenticate: Basic realm="ReadyNAS Admin"
< Content-Length: 217
< Connection: close
< Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>403 Forbidden</title>
</head><body>
<h1>Forbidden</h1>
<p>You don't have permission to access /dbbroker
on this server.<br />
</p>
</body></html>
* Closing connection 0
As you can see, it has the token, but it still reports "Forbidden".
  • StephenB's avatar
    Did you try using https in your script instead of http?
    • jtnn60's avatar
      jtnn60
      Of course!  I get the same error in both situations.
      • StephenB's avatar
        One option is install sshpass and switch to ssh - using rnutil rn_shutdown to do what you want.  You'd of course need to enable ssh
        # sshpass -f <(printf '%s\n' nas-admin-password) ssh root@nas-ip-address rnutil rn_shutdown
        Note I haven't tested the above command (though ssh root@nas-ip-address rnutil rn_shutdown definely works if you type in the password.
ProSupport for Business
