SimonClark100's avatar
Apr 17, 2023
Drives moved to NAS 104 from another NAS 104 say volume is redundant why?
I have 2 NAS 104's and I purchased the second one just to keep as a hardware backup. The chassis seems to have died and will no longer finish booting. I've tried OS recovery but it never seems to complete.
So, I put plan B into action and moved the drives to my spare 104 but even though it recognises them it says they contain reduntant volumes and in order to use them I need to delete them. I kind of hoped it would just mount the drives and off I'd go.
What can I do to add these drives to my spare? It seems to me to be crazy that the hardware can be a single point of failure and cause all of the data to suddenly become inaccessible.
Thanks
  • StephenB's avatar
    SimonClark100 wrote:
    So, I put plan B into action and moved the drives to my spare 104 but even though it recognises them it says they contain redundant volumes
    Do you mean an inactive volume?
    Are you using FlexRAID or X-RAID.
    • SimonClark100's avatar
      SimonClark100
      Stephen, thank you for your reply.
      Yes, the exact wording is 'Remove inactive volumes to use the disk. Disk #3,4.
      The unit looks configured for X-RAID on both volume sets (green bar under words).
      • StephenB's avatar
        Most likely the problem is that volume is simply out of sync.  That can happen if there were cached writes that were never written to the disks when the old NAS failed.
        I suggest getting the full log zip (download it from the logs page).  If you like, you can send me a private message (PM) with a download link to the zip file (dropbox, google drive, etc) and take a look.  Best not to post the download link publicly, as there is some privacy leakage (for instance, your email address would be in the log file).
        There is a way to forcibly mount the volume from the linux command line.  There would be some loss of data (since some writes were lost) - it's hard to say how much.  Another option is to connect all four disks to a Windows PC, and use RAID recovery software that supports BTRFS.  ReclaiMe is one package that folks have used here with success.
ProSupport for Business
