JimmyBudz's avatar
JimmyBudz
Eggdrop Irc Bot
hey guys i have a problem i want my nas to connect to irc and stay in the channel so i can dcc relay files to it
i have installed eggdrop
# apt-get install eggdrop
and it works fine but when i try and run it i get
Eggdrop v1.6.17 (C) 1997 Robey Pointer (C) 2004 Eggheads
[17:08] --- Loading eggdrop v1.6.17 (Mon Feb 4 2013)
[17:08] * CONFIG FILE NOT LOADED (NOT FOUND, OR ERROR)
now i dont know where to find the config file or where to put it cause i can make one but just dont know where to put it
any ideas or is there another way i can do this
1 Reply
  • You have to make a config file, else it won't know who the master is, what channels to join, etc.
    I haven't used EggDrop in a good 10 years, but there should be a default config file with it, then you can copy/modify, and use ./eggdrop -m <conf>
ProSupport for Business
