Orbi WiFi 7 RBE973
Enable SMB 2 on ReadyNas x86 v4.2.31
jgrimm
Is it possible to enable SMB 2 on legacy ReadyNas devices running SAMBA 3.6?
Model: RNDU6000 (ReadyNAS Ultra 6)|READYNAS ULTRA 6 (DISKLESS)|EOL
Message 1 of 10
Accepted Solutions
Guru
Re: Enable SMB 2 on ReadyNas x86 v4.2.31
If your Windows version gives you a free NFS client, you could also potentially switch to that: https://community.netgear.com/t5/Using-your-ReadyNAS/No-access-to-shares-after-disabling-SMB1-as-rec... Then disable SMB altogether.
You could also try adding the following lines to the [global] section of the /etc/samba/smb.conf file and rebooting the NAS:
min protocol = SMB2
max protocol = SMB2
SMB2 support is only "experimental" in your version of SAMBA, so you might run into issues.
OR, convert your ultra to run OS 6, and that will give you SMB3 support.
Message 4 of 10
All Replies
mdgm-ntgr
NETGEAR Employee Retired
The SMB2 support in Samba 3.6 is experimental, but you can enable it via SSH.
I would stick with SMB1 on it.
Message 2 of 10
jgrimm
So I have two options:
Go against Microsoft's advice and enable SMB1 on my PC
OR
Go against Netgear's advice and enable SMB2 on my NAS
Which option would you recommend?
If I want to take my chance with SMB2 on my NAS (as I'm just using it as a backup duplication repository), how I do I enable it via SSH?
Thanks.
Message 3 of 10
Guru
min protocol = SMB2
max protocol = SMB2
Message 4 of 10
Mickoz
Is there a guide on how I would convert to OS 6 from RAIDiator 4.2.31?
Model: ReadyNAS RNDP600U|ReadyNAS Ultra 6 Plus Chassis only
Message 5 of 10
bedlam1
Prodigy
 This THREAD covers it and applies to not just an Ultra 6, but read it all and not just the solution, there is information about checking/upgrading Bios which should be done in OS 4
Message 6 of 10
Mickoz
Thanks.  I've already upgraded to OS6.  Completely missed the BIOS step, hopefully it doesn't cause any lsting issues.
Do you know if you can still update the BIOS from OS6?
Message 7 of 10
bedlam1
Prodigy
No I don't, I suppose you could go back to OS 4.2 to do it then install OS6 again Smiley Sad
Message 8 of 10
mdgm-ntgr
I think the BIOS update for the Ultra 6 was to address a WoL issue. If you're not planning on using that I wouldn't worry about whether the BIOS is out of date or not.
Message 9 of 10
Mickoz
Thanks Team,
Its working for now and I must say it looks much nicer than the clunky old interface.  I have not been able to install Plex yet, perhaps I need a reboot.
Sorry I didn't find the original thread 🙂
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 48598 views
  • 3 kudos
  • 5 in conversation
Announcements
