× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Error Volume data Raid Level 1, Not Redundant
Jeje
Firmware 6.5.2
After adding a second 2 TB WD RED HDD both disks are being recognized and have a green check
But there is an error saying Volume Dta: RAID level 1 , Not Redundant; 679.5GB (38%) of 1.8 TB used.
Diagnostics: Successfully completed diagnostics System
  • Disk 1 has 1 Current Pending Sectors
Logs
  • 2016-09-26 12:35:25: md/raid1:md127: sda: unrecoverable I/O read error for block 64161792
  • 2016-09-26 12:26:40: md/raid1:md1: Disk failure on sdb2, disabling device.
  • 2016-09-26 12:26:35: md/raid1:md0: Disk failure on sdb1, disabling device.
  • 2016-09-25 10:39:05: md/raid1:md127: sda: unrecoverable I/O read error for block 64161792
  • 2016-09-24 10:51:21: md/raid1:md127: sda: unrecoverable I/O read error for block 64161792
  • 2016-09-24 10:30:47: md/raid1:md127: sda: unrecoverable I/O read error for block 64161792
RAIDar -> admin -> system -> overview says that the system is degraded.
RAIDar -> admin ->  system -> volumes shows two disk - RAID 1. Data 270.62GB; Momentual 408.86GB; available 1.18GB: type RAID 1.
Unfortunately I do not have a high skill experience to understand what is wrong.
Anybody who could help me?
Thanks.
Model: ReadyNAS Remote|
Message 1 of 14
Accepted Solutions
Guru
Re: Error Volume data Raid Level 1, Not Redundant
@Jeje wrote:
I had quite a number of spikes and surges because of tripping of the electric circuit. Maybe that has to do something with it?
A surge could have created some damage.  Do you use a UPS?
The WD Red has a 3-year warranty, so you can RMA it.  Western Digital will send you a recertified replacement, not a new disk.  I'd probably do the RMA, but also buy a new replacement disk for the NAS.  Then either use the RMA replacement somewhere else, or keep it on hand as an emergency spare.
Message 4 of 14
All Replies
Guru
The messages say disk 1 is failing (data can't be read) - I'd replace it.
You could get more details by downloading the log zip file and looking in disk_info.log.  Another way to confirm disk health is to test the disks in a Windows PC with Western Digital's lifeguard.
How old is the disk?
Message 2 of 14
Jeje
Thank you Stephen. I bought the first disk in Sep 2014.
I had quiet a number of spikes and surges because of tripping of the electric circuit. Maybe that has to do something with it?
Message 3 of 14
Guru
Message 4 of 14
Jeje
Thanks Stephen.
This really was very helpful as you showed me things I didn't know.
I was able to create a RMA and will also buy a new replacement.
Message 5 of 14
Jeje
It seems that I have lost about a 1TB on data on disk 1. I can see the folders in explorer but when clicking on NETWORK-->NAS, it says the folder is empty.
RAIDar : RAID level 1 inactive, ; 0 MB (0%), of 0 MB used. I just loaded one disk to backuo the data.
System status is healty.
Volumes: Inactive disk, red colored with a green indicator.
If I load two disks, both disks are colored red with a green indicator.
Diagnostices:
Logs
  • 2016-09-29 14:40:28: EXT4-fs error (device md0): ext4_lookup:1588: inode #2639: comm readynasd: deleted inode referenced: 3253
  • 2016-09-29 13:39:27: EXT4-fs error (device md0): ext4_lookup:1588: inode #2639: comm readynasd: deleted inode referenced: 3253
  • 2016-09-29 12:38:25: EXT4-fs error (device md0): ext4_lookup:1588: inode #2639: comm readynasd: deleted inode referenced: 3253
  • 2016-09-29 11:37:23: EXT4-fs error (device md0): ext4_lookup:1588: inode #2639: comm readynasd: deleted inode referenced: 3253
  • 2016-09-29 10:36:21: EXT4-fs error (device md0): ext4_lookup:1588: inode #2639: comm readynasd: deleted inode referenced: 3253
  • 2016-09-29 09:35:19: EXT4-fs error (device md0): ext4_lookup:1588: inode #2639: comm readynasd: deleted inode referenced: 3253
  • 2016-09-29 08:34:17: EXT4-fs error (device md0): ext4_lookup:1588: inode #2639: comm readynasd: deleted inode referenced: 3253
I have created a RMA. Before I send back this drive is there a way to recover the data?
Message 6 of 14
Guru
The snippet you posted is on the OS partition (which is formatted as ext on the RN100 series), not the data partition (which is btrfs).
Netgear has a data recovery service, you could try that.  They will charge (and data recovery is expensive).  There are some software packages you could also try - but I haven't used any, so I cannot recommend one.
Message 7 of 14
Jeje
Thanks Stephen. Really appreciate your help.
Things changed. Now it says that the system is healthy and it sees both the disks. But it didin't see any volumes at first. So I created one "Test" and it needed 4 hrs to sync.
There seems to be 32.81MB on data on the disk but in explorere it says that the network drive doesn't have any folders. It drives me crazy.
If I click on the disks in admin/volume page, I cannot do anything.
What would you recommend. Just to send back both teh disks or do a factory reset on the ReadyNas? Thanks for your help.
Message 8 of 14
Guru
The btrfs file system will show some space allocated even if the volume is empty.  So that part is normal.
Can you download the logs, and look at the disk_info.log?  You can post it here (removing the two serial numbers if you like).
If both disks look healthy, I'd do a factory reset next (since there was file system corruption in the OS partition earlier on).  But I think we should confirm disk health first.
Message 9 of 14
Jeje
This is what the disk_info.log says:
Device: sda
Controller: 0
Channel: 0
Model: WDC WD20EFRX-68EUZN0
Serial: WD-WMC4M1635698
Firmware: 80.00A80
Class: SATA
RPM: 5400
Sectors: 3907029168
Pool: Test
PoolType: RAID 1
PoolState: 1
PoolHostId: e348c4d
Health data
ATA Error Count: 5
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 31
Start/Stop Count: 129
Power-On Hours: 18072
Power Cycle Count: 98
Load Cycle Count: 1912253
Device: sdb
Controller: 0
Channel: 1
Serial: WD-WCC4M1ZVU14K
Firmware: 82.00A82
Class: SATA
RPM: 5400
Sectors: 3907029168
Pool: Test
PoolType: RAID 1
PoolState: 1
PoolHostId: e348c4d
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 30
Start/Stop Count: 29
Power-On Hours: 255
Power Cycle Count: 17
Load Cycle Count: 15
It also seems that one account was deleted Sep 29th. Have no clue how.
Thu Sep 29 2016 23:51:00 System: Automatic disk spin-down enabled.
Thu Sep 29 2016 23:13:05 Volume: Volume data is resynced.
Thu Sep 29 2016 23:12:24 Volume: Resyncing started for Volume data.
Thu Sep 29 2016 23:12:10 Disk: Disk Model:WDC WD20EFRX-68EUZN0 Serial:WD-WCC4M1ZVU14K was added to Channel 2 of the head unit.
Thu Sep 29 2016 22:56:08 System: Antivirus scanner definition file was updated to 201609291956.
Thu Sep 29 2016 22:40:25 Account: User 'jejeagency@gmail.com' was deleted.
Thu Sep 29 2016 22:39:53 System: ReadyNASOS background service started.
Thu Sep 29 2016 15:08:04 System: The system is shutting down.
Thu Sep 29 2016 3:07:33 Disk: Disk in channel 2 (Internal) changed state from RESYNC to ONLINE.
Thu Sep 29 2016 3:07:33 Volume: Volume data is resynced.
Message 10 of 14
Guru
The load cycle count on the first drive is way too high for a WDC Red - something is odd there.
I think I'd try the reset anyway, but maybe repost the stats again after the reset completes.
Message 11 of 14
Jeje
After doing a Factory Reset (with 2 other new disk, - trying not to lose any data from the previous marked corrupted disk meant for RMA), the newest firmware (6.6.0) was installed automatically and the stats are:
  • No errors found.
Logs
  • No errors found.
The system is resyncing which will take another 3 hrs. After that I will try to replace the two disks with just the one which is meant for RMA to see if I could recover data.
Good news is that the REadyNAS is accesible again through the File Explorer.
Message 12 of 14
Guru
Just make sure the NAS is powered down when you switch the disks.  I'd label the new ones by slot (not strictly necessary, but does no harm).
I hope you can recover data.
Message 13 of 14
Jeje
Unfortunately the RMA disk is no longer readable.
It is packed to be shipped.
Thanks for all the great help and information. It was a pleasure.
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 3445 views
  • 0 kudos
  • 2 in conversation
Announcements
