lupis's avatar
lupis
HTTP Redirect on load to specific share
Hi,
I have just recently migrated from share to user security. One thing that has changed its behavior is the redirect option for HTTP protocol that I had previously set up under share security. I had created a webserver and a share called website. This contained the index.html webpage I wanted to load as default when connecting to my NAS. I set up this share with read/write access under CIFS and read only access under HTTP/S. Then under standard file protocols switched to the website for the redirect option under HTTP protocol. This all worked fine before switching to user security.
The settings under CIFS for this share is the same as before (Read/Write), and wrote the user that has the privileges for this share, but when I try to change the default access for this share to read only under HTTP/S it reverts back to Not activated. Furthermore when I go to the standard file protocol for HTTP, under the redirect dropdown there is only the "Not Selected" option available and not all the website share visible as before under share security.
ProSupport for Business
