× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Hard drive failure during rebuilt - next steps?
rmurgz
Tutor
Hi there,
I have just undertaken an upgrade of the hard drives in my ReadyNAS314 as follows:
* Bays 1 & 2 - 2 x 6TB WD Red Pro - to remain the same
* Bays 3 & 4 - 2 x 2TB WD Red Pro to 2 x 6TB WD Red Pro
I swapped out Bay 3-4 at which point the RAID started to rebuild. I've returned overnight to see a warning that the NAS is degraded and the drive in Bay 1 has disappeared from the
What I really need help with is:
1. How can I check whether all my data is ok?
2. How can I check whether this is a drive failure or issue with the NAS. The console displays the volume as missing (rather than corrupted) - image below
3. What to do next!
Many thanks
Richard
Model: RN31400|ReadyNAS 300 Series 4- Bay
Message 1 of 6
mdgm-ntgr
NETGEAR Employee Retired
Re: Hard drive failure during rebuilt - next steps?
Send in your logs (see the Sending Logs link in my sig)
Message 2 of 6
rmurgz
Tutor
Thanks for getting back to me. Will be with you in next 5 minutes.
Smiley Happy
Message 3 of 6
mdgm-ntgr
Looks like a bad disk to me. I can see I/O errors.
Is your backup up to date?
Message 4 of 6
rmurgz
Tutor
Hi mdgm,
Back-ups are up to date though I'd rather not restore from them as it's a bit messay.
Am not sure in which log you're seeing the I/O errors.
When I looked at the logs on the ReadyNAS portal it looks like the NAS had finished resyncing with the new drive in bay 3 before the drive in bay 1 failed. Am I safe to stick a new 6tb drive into bay 1 to restore my RAID5 failover or are there bigger issues that have been in play for longer?
Apologies in advance if these questions seem dumb 😞 and thanks again for all your help.
Message 5 of 6
dmahon1
Looks like you got lucky, the RAID is viable but degraded, and can indeed just swap your remaining new drive with the failed drive 1.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2493 views
  • 1 kudo
  • 3 in conversation
Announcements
