× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Install Crashplan 4.8.2 (Updated May 2017)
jclaracq
Star
Hi everyone.
Following a previous post on Install Crashplan (August 2016). I managed to fix my installation again with last version of ReadyNAS 6.7.2 and Crashplan 4.8.2.
I also simplified the instruction to make it less confusing. Here it is below:
UPDATE May 2017: Crashplan version 4.8.2
Step 1: Installation
Add some tools to READYNAS:
apt-get install apt-utils
apt-get install dialog
dpkg-reconfigure debconf
Set the debconf level to "dialog" and "medium"
It turns out the pre-installed version of cpio doesn't quite cut it. Replace it:
apt-get remove busybox-cpio
apt-get install cpio
Make a temp directory
mkdir /tmpcd
cd /tmpcd
Download last version of linux CrashPlan (Check on website)
wget https://download.code42.com/installs/linux/install/CrashPlan/CrashPlan_4.8.2_Linux.tgz
Unzip the file:
tar -xvzf CrashPlan_4.8.2_Linux.tgz
cd crashplan-install
./install.sh
if upgrading, you need to remove a previous version: ./uninstall.sh -i /usr/local/crashplan
CrashPlan will install to: /usr/local/crashplan or install in /apps/crashplan
And put links to binaries in: /usr/local/bin
And store datas in a share (I prefer to put it on a USB media to not waste space on NAS): /media/USB_HDD_2/crashplan-backup (or /data/crashplan)
Your init.d dir is: /etc/init.d
Your current runlevel directory is: /etc/rc5.d
Is this correct? (y/n) [y]
Reset debconf to non-interactive (using "noninteractive" and "medium" as settings):
IMPORTANT:
edit now (use vi or nano):
/usr/local/crashplan/conf/my.service.xml
change
<serviceHost>127.0.0.1</serviceHost>
to
<serviceHost>0.0.0.0</serviceHost>
Doing so will enable the STEP 2 here after
restart daemon:
service crashplan restart
Step 2. Configuration
These instructions are adapted from CrashPlan support site here:
https://support.code42.com/CrashPlan/4/Configuring/Using_CrashPlan_On_A_Headless_Computer
1. Install the client on your laptop or desktop from CrashPlan.
2. Crashplan requires you to copy a UI key form the backend service on the headless system (the ReadyNAS in our case) to the client system (the computer we are using the desktop app on).
Copy the contents of /var/lib/crashplan/.ui_info on the ReadyNAS to the appropriate file on your client computer (see below). Do a backup of the file on your client computer to undo the connection if needed.
For example...
ReadyNas .ui_info
4243,xxxxxx-xxxx-xxxx-xxxx-xxxxxxxx,192.168.0.120
The correct client file will be in the location below depending on your client OS.
Locations Of .ui_.properties (source)
Windows Vista, 7, 8, 10, Server 2008, and Server 2012
Installed for everyone: C:\ProgramData\CrashPlan\conf
To view this hidden folder, open Windows Explorer and paste the path in the address bar.
Installed per user: C:\Users\\AppData\<Local|Roaming>\Programs\CrashPlan\conf
Windows XP
Installed for everyone: C:\Documents and Settings\All Users\Application Data\CrashPlan\conf
Installed per user: C:\Documents and Settings\\Application Data\Programs\CrashPlan\conf
​To view this hidden folder, open Windows Explorer and paste the path in the address bar.
OS X
Installed for everyone: /Library/Application Support/CrashPlan/conf/.ui_.properties
Installed per user: ~/Library/Application Support/CrashPlan/conf/
Linux: /usr/local/crashplan/conf
Solaris: /opt/sfw/crashplan/conf
Now fire up your desktop app and you should be greeted with the setup process.
3. Open the CrashPlan app on your client and setup CrashPlan as per their instructions on their site.
4. You can then load up your client and set it up, and as with any other clients you also install the CrashPlan app on to (and either login with same account, or using your CrashPlan ìFriend Codeî) you will then be able to see your ReadyNAS as a backup destination (under ìComputersî)?. If you have more than one ReadyNAS that you install this on to, you can also setup backups to run between
CONGRATULATIONS YOU ARE DONE!
Message 1 of 2
Accepted Solutions
JennC
NETGEAR Employee Retired
Re: Install Crashplan 4.8.2 (Updated May 2017)
Hello jclaracq,
Thank you for sharing your resolution and/or workaround. We greatly appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
Message 2 of 2
All Replies
JennC
Hello jclaracq,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2775 views
  • 1 kudo
  • 2 in conversation
Announcements
