- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Share Folders - What Settings For PLEX?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've just updated my ReadyNAS Ultra 4 Plus to firmware v6.10.2, due to my newer Samsung TVs not being able to see Plex.
The ReadyNAS is only used maily for serving movies, music etc around the home, with no outside world access required.
Connected to my FRITZ!Box router via a Linksys unmanaged switch, the ReadyNAS is used to serve media to 5 TVs around the home (only 2 in use at any one time) and various smartphones and tablets..
The newer ReadyNAS administrator interface is so very alien to me after using the old version for so long..
So I am setting up my folder structure as it was before in which to store my:
Backup Data
Kids Movies
Movies
Music
Music Videos
Photos
I'm just a bit confused as to what I need to enable or disable under the various tabs found in the settings for each share, such as:
Properties | Network Access | Snapshots | File Access
For the Multimedia folders above, I have the following selected/de-selected:
Properties:
Bit Rot Protectection ✘
Auto-Defrag ✔
Size (Quota) ✘
Network Access (Security):
SMB ✔ - NFS ✔ - AFP ✘ - FTP ✘ - RSYNC ✘ - HTTP ✘ - DLNA ✔ - iTunes ✘
Everyone: Read Only
Admin: Read/Write
Users: None
Admin: Read/Write
Snapshots:
Smart ✔
Daily ✔
Allow Snapshot ✘
File Access
Folder Owner: Admin
Folder Group: Admin
Grant Rename & Delete Privileges ✔
Everyone: Read Only
Folder Owner: Read/Write
Folder Group: Read Only
Admin: Read/Write
Users: None
The regular data folders are much the same, but without DLNA selected under Network Access
I would just like someone to point out where I may have gone wrong and what I should be selecting/deselecting.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just tried copying some folderrand files over as a test and the Owner is still NAS-8B-C8 despite the name being changed to ReadyNAS.
I wonder if it needs a reboot?
It's been up 1 day 7 hours and I cannot remember shutting it down after changing the Host Name.
UPDATE!
That what it was after all the fannying about I've been doing today!
Thanks for the info guys!
Gotta accept my own post as a solution now, which makes me feel like a right numpty!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Share Folders - What Settings For PLEX?
@Ripperoo wrote:
File Access
Folder Owner: Admin
Folder Group: Admin
Everyone: Read Only
Admin: Read/Write
Users: None
I'd set Everyone, Users, and Folder Group here to Read/Write (and only depend on Network Access to manage access). I'd also disable NFS unless you have a linux PC that needs it. But I don't think this is related to your problem.
Is the plex app installed on your Samsung TVs? Are they newer than 2016? If they are older than that, you need to set "secure connections" to "preferred" in the plex server settings.
Plex has it's own DLNA server built in - if you want to use that, you should turn off DLNA in your share settings, and disable DLNA on system->settings->services. Note you would also need to enable DLNA in the plex server settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I manage my content using Windows Explorer and don't have a Linux computer, so I can basically just leave SMB activated and all my devices will stream OK from the ReadyNAS? Cool!
I have 5 Samsung TVs all with Plex on them and they range from 2013-2019, so thanks for the tip on "Secure Connections".
Is the problem you refer to, the one I mentioned in another thread?
If so, I think that issue is now resolved and was seemingly caused by one or more Firefox add-ons.
Once I removed them, the error messages have not occurred again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I meant to not being able to use plex with the Samsung TVs. That was inferred from the title of your post.
Well, SMB is the only file sharing protocol you need. Streaming with Plex would either be using the proprietary plex protocol (implemented in the plex server), or DLNA (also enabled in the plex server settings).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the that.
Just noticed that the folders I've copied onto the ReadyNAS already now display the owner as NAS-66-C8\Admin.
I'm guessing this is because I'd originally set the set the Folder Owner and Folder Group of the affected Shares as Admin before I copied over the first batch of files.
What do I need to do to:
1. Change ownership of the files already copied over?
2. Maintain the original ownership of Folders and Files copied over in future.
I had this issue on my ReadyNAS when it was on the the older v4 firmware, but managed to change a setting and refresh the existing files, but as I've said previously, the new interface leaves me lost.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well, yes - you did set the ownership to admin.
Why do you think this is something you need to change?
What do you want to change the ownership to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had access problems when trying to delete, rename stuff on the ReadyNAS from a different PC a few years ago and seem to remember it had something to do with the ownership of the files and folders.
I don't want to allow read/write access to all just in case any local users accidentally move, renames or deletes anything.
I know some of my questions probably seem a bit stoopid, but I'm having to relearn all this stuff after not using it for a long time and also due to the newer interface (well, new to me anyway).
I therefore am very appreciative of any and all advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Forgot to add my previous reply and cannot edit it, but I wanted to change the ownership to my PC's Name from the default NAS-8B-C8
I'm guessing there is a way to change the NAS name so it is reflected in the ownership name of files?
If so, how can I do that?
I'm guessing the editing of posts must is time-limited on the Netgear Community Forums?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The NAS name is there because the files are owned by a NAS account. That's not something you can change. There's also no reason to change it. You have full access to the files.
You can of course change the NAS name if you like.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I checked I had already changed the name to................ReadyNAS. I know, not very original. LOL
Anyhow I'm sure when I did the same on the same ReadyNAS on the old firmware (v4.***), that the Owner as shown in Windows Explorer was something like ReadyNAS/root or ReadyNAS/admin or something similar.
Maybe it was even changing root/admin/guest under File Access in the settings for each Share?
I certainly don't remember seing anything unfriendly like NAS-8B-C8/admin in the Owner column in Windows Explorer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Ripperoo wrote:
I certainly don't remember seing anything unfriendly like NAS-8B-C8\admin in the Owner column in Windows Explorer.
NAS-8B-C8 must have been the hostname of the NAS. If you'd changed it to ReadyNAS now, then that's what Windows should be showing you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
UPDATE!
