kderski's avatar
kderski
Question regarding ReadNAS file system and LUN data
Hey everyone,
Looking for some guidance. I have created a few ISCSI LUNs on our ReadyNAS that we use for Vmware datastores. One datastore in particular has ran into issues that I wont delve into here save to say I cant get to the files stored on it. I tried to mount this LUN elsewhere so I could run some recovery tools against it but find im not able to browse it once I have it mounted.
As a kinda last ditch effort I Putty into the ReadyNAS itself to see how the device is storing the data under the covers to see if there was a way to move the data to say a share somewhere else, but I have found that while navigating the BTRFS filesystem underneath, I can find The Volume Subfolders and even the particular LUN folder itself, but those directories are showing up empty, even with ROOT access.
So the question I have is it possible to move ISCSI LUN data from the underlying OS of the readyNAS or even view it or has someone had a similar situation to this that they were able to get to that data?
Thanks in advance
1 Reply
  • StephenB's avatar
    You should see a hidden .iscsi folder in the LUN folder
    root@NAS:/data/TestLun# ls -als
    total 32
     0 drwxr-xr-x 1 root root  12 Aug 10 18:26 .
    32 drwxr-xr-x 1 root root 498 May  7 12:16 ..
     0 drwxr-xr-x 1 root root  74 Aug 10 18:26 .iscsi
    In that subfolder you should find the backing store for the LUN
    root@NAS:/data/TestLun/.iscsi# ls -als
    total 1048580
          0 drwxr-xr-x 1 root root         12 Aug 10 18:26 ..
    1048576 -rw-r--r-- 1 root root 1073741824 Aug 10 18:26 iscsi_lun_backing_store
          4 -rw-r--r-- 1 root root         36 Aug 10 18:26 .serial_number
    iSCSI LUNs are raw block storage, so the contents of the backing store are opaque to the NAS.
    There are some software tools that might help.  For instance, ReclaiMe: https://www.reclaime.com/library/iscsi-recovery.aspx
    This isn't something I've needed to do, so it is not a recommendation - just a pointer in a direction that might be helpful to you.
ProSupport for Business
