pmcwilliam's avatar
pmcwilliam
RR4360X - RAID 60 volume size incorrect
I have a ReadyNAS RR4360X. It had 36 x 12 TB Seagate ST12000NE007 drives installed (10.9 TB actual space)
Running RAID 60 with 3 Raid Sets, volume showed data 265 TB
I then added 9 x 12 TB Seagate ST12000NE007 drives for a total of 45 drives in 3 RAID sets
Completed the expand operation to only get 279 TB of space
Raid calculators show that I should have approx 425 TB of space
Attached image shows that RAID set 3 has unallocated space of 135 TB but I cannot see how to get the unallocated space to become allocated
Have updated firmware and restarted
There are no expand or other options listed under the RAID sets
Any help would be apprieated
Thank you
    What you are seeing is normal.
    Add data to your data volume and that space should become allocated as needed. This is how BTRFS works by design.
    It's not recommended to fill the data volume too full though.
    • pmcwilliam's avatar
      pmcwilliam
      Thank you for your reply
      My issue is that I cannot add space to my iSCSI LUN's or create new iSCSI LUN's because the unit does not think it has free space
      So while it might be normal if I was adding data to the volume, I am trying to expand iSCSI
      I have attached screen shots, I do see that under RAID Group #3 some space has moved from Unallocated to Data Allocated
      Any thoughts on how to expand current LUN's or create new iSCSI LUN's when the unit does not think it has any free space?
      Thanks
      Paul
      • mdgm's avatar
        mdgm
        Virtuoso
        Edit: Hmmm. Re-read your post.
        This is a bit strange. Maybe if you filled up the metadata on the first 2 layers (create a new share with lots of small files) then some metadata will have to be allocated on RAID layer 3 that might change things.
        Metadata contains data about data. Some of this is fixed per file no matter whether your file is 1KB or 1TB which is why adding lots of small files is best.
        I wonder if metadata needs to be allocated on a layer for it to be used for iSCSI LUNs.
        I would make sure your backup is up to date before trying that.
ProSupport for Business
