× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 102 Communication Error when checking for Updates
bpichany
Tutor
My ReadyNAS 102 with Firmware 6.10.7 pops-up a Communication Error 6001010060, when Check for Updates. Any ideas?
Message 1 of 15
Accepted Solutions
JeraldM
NETGEAR Employee Retired
Re: ReadyNAS 104 running 6.10.7 with the same problem that appeared in the last few days.
Hi!
It should be fixed now.
Please let us know if you're still encountering the issue.
JeraldM
NETGEAR Community Team
Message 9 of 15
All Replies
JeraldM
Re: ReadyNAS 102 Communication Error when checking for Updates
@bpichany,
Welcome to the community!
Could you enable Secure Diagnostics mode on the NAS and PM me the 5-digit port number?
JeraldM
Message 2 of 15
bpichany
Tutor
Done, and I PM you the 5-digit port number via email.
Message 3 of 15
Ray2
Luminary
Same problem began only yesterday.  No changes to firmware and internet works fine otherwise?  Error message goes on to say: "Check internet connection, DNS settings, or proxy settings".
None of those things have changed in my system.
Looking forward to reply.
Message 4 of 15
brw1
Tutor
I have a ReadyNasRN31221D.
I'm also suddenly having the same error when attempting to check for updates. It was fine about 2 weeks ago.
Everything else is working fine except my ASUS router now won't let me set DNS unless I also set DDNS which I never needed to before!
Message 5 of 15
Th3Cr0w
Initiate
Message 6 of 15
polomorales
Did you get a response or solution? I have the same problem....
Message 7 of 15
Guru
Netgear responded here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/DNS-error-message-6001010060-readycloud-...
They said they are working on it and will fix it ASAP.
Message 8 of 15
JeraldM
Hi!
JeraldM
Message 9 of 15
Ray2
Luminary
I'm running two units:  1) a 314  2) a 318----both 6.10.7.
Both are okay now. They now respond as they did before when clicking for a check of update, they send the message that my system is already running the most up to date.
All is as it should be. "Time" has resumed its shape.  🙂
Thank you.
Message 10 of 15
Th3Cr0w
Initiate
My RN104 is working fine now - thanks!
Message 11 of 15
brw1
Tutor
Working ok now for me!
Message 12 of 15
bpichany
Tutor
Mine works fine now. Thanks!
Message 13 of 15
bpichany
Tutor
It works fine now. Thanks!
Message 14 of 15
polomorales
Mine seems to be working fine now.
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 4033 views
  • 11 kudos
  • 7 in conversation
Announcements
