LiorDesign
May 16, 2019Tutor
ReadyNAS 104 keeps powering down randomly
Hi,
Ineed some help with my readyNAS 104 (running 4x1TB WD red hdd's).
It's been working great in my home office for the past several years with regualr updates to the firmware. This week out of the blue I discovered it started powering down at random times with no apperent reason. I tried upgrading to the latest 6.10.0 Hotfix 2 firmware but the problem still pressits. Sometimes it powers back on after a couple of hours and sometimes it doesn't. I don't have any power timer enabled and the unit is connected to a UPS.
all I can see in the logs is:
| May 15, 2019 06:45:24 PM |
System: ReadyNASOS background service started. |
| May 15, 2019 04:45:13 PM |
System: The system is shutting down. |
any help would be appreaciated.
thanks.
LiorDesign
- Retired_MemberMay 17, 2019
So, lets try one of the back usb ports instead to connect the ups and see what happens.
- Retired_Member
Hi LiorDesign, I see three areas your could work on: (3) The box itself, (2) the external power supply or (1) the ups and would start with the latter.
(1) Just disconnect the nas from the ups (power and data) and directly connect it to a power outlet in the wall. You know the frequency of the shutdowns and reboots already very well and will be able to decide, whether this change makes any difference. Should the nas stop misbehaving you can continue to troubleshoot the ups.
(2) To test, whether the external powersupply is the problem you need a spare part. Well 'nuff said.
(3) Hopefully you do not end here, which might be a never ending story and probably is a hint of fate to start thinking about replacing that Methuselah should you not want to be surprised one day by its "sudden and unexpected" death.
Good luck with fixing and kind regards
- HopchenProdigy
To add, I can take a look in the logs to see if I can determine why it shuts down. If you want, download the logs from the NAS. Then upload the zip file to a Google drive or similar and share it via a link. PM me the link and I will take a look for you. Cheers
great advise, thank you. Staring to test and will re post my findings.
- HopchenProdigy
The NAS is complaining about the usbfs module before it crashes. Example below from the kernel log:
May 15 19:43:17 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 2 ret -110 May 15 20:27:11 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 2 ret -110 May 15 21:52:35 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 2 ret -110 May 15 22:31:39 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 3 ret -110 May 15 22:32:04 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 2 ret -110 May 16 05:02:06 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 3 ret -110 May 16 05:19:15 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 3 ret -110 May 16 05:19:30 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 2 ret -110 May 16 05:20:20 LIORDESIGN kernel: usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd usbhid-ups rqt 161 rq 1 len 3 ret -110 May 16 05:53:17 LIORDESIGN systemd-shutdown[1]: Sending SIGTERM to remaining processes... -- Reboot --
Do you have any USBs attached to the NAS in general?
Cheers
