× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 104 to Ultra 6 Migration?
I have a 104 with 4 drive in raid 5. How can I hot swap them into my Ultra 6? I will upgrade the Ultra to OS6 prior. Thx.
Message 1 of 5
Accepted Solutions
Guru
Re: ReadyNAS 104 to Ultra 6 Migration?
I suggest repurposing the RN104 as a backup NAS instead (though that might require purchasing new disks, depending on the state of the Ultra).
You say "hot swap", but I am assuming that you mean "migrate".  The process requires you to transfer the disks with the systems powered down.  It's best to update your backup before you manipulate the disks.
  1. Convert the Ultra to OS-6 first with a scratch disk, and then make sure the firmware is the same on the two systems.
  2. Uninstall your apps on the RN104 before migrating.
  3. Power down both systems
  4. Remove the scratch disk in the Ultra
  5. Move the RN104 disks to the Ultra (preserving the slot order)
  6. Power up
  7. Reinstall your apps.
One caveat - normally x86 systems use BTRFS for both the OS partition and the data volume.  Arm systems use EXT for the OS partition (but of course use BTRFS for the data volume).  When you migrate, the process won't convert the OS partition formatting, so it will remain EXT.  This won't create any problems, but you might notice it if you use ssh (and it will also be apparent in the logs).
Message 2 of 5
All Replies
Guru
  6. Power up
Message 2 of 5
Thanks!
Message 3 of 5
Worked like a charm. Thanks!
Message 4 of 5
Guru
I'm glad I could help.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1183 views
  • 1 kudo
  • 2 in conversation
Announcements
