× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS 4220 doesn't recongize new drive
clewis
Our 6-month old 4220 had a drive fail. It was one of the included drives (6 bays were occupied when the unit arrived) so netgear dispatched a replacement drive to us. We pulled the bad drive (drive #4 per web admin) and noticed we didn't get a hot plug alert in the logs. We installed the drive Netgear sent, again, we didn't get a hot plug alert in the logs and the volume didn't start rebuilding. We're running in RAID 6 X-RAID. We have a couple of older ReadyNAS units around and we're used to seeing the OS respond immediately when a drive is inserted or removed.
What are we missing toward getting the device to integrate this new drive into the volume.
It's 6 2-tb drives, by the way, and the OS is fully patched to the latest RAIDiator.
Message 1 of 6
mdgm-ntgr
NETGEAR Employee Retired
Re: ReadyNAS 4220 doesn't recongize new drive
Are you using X-RAID?
What do you see for slot 4 in the web admin interface?
Did you make sure the replacement disk had no partitions on it before adding it?
Message 2 of 6
clewis
Yes, it's RAID6 and X-RAID. In the web admin, bay 4 shows a red LED. When I hover over it it indicates disk state is "failed". Temperature is "-1". It still indicates it's a Toshiba MK2002TSKB drive even though the replacement drive netgear sent is a Western Digital.
We didn't put the drive into a computer before putting it into the ReadyNAS...since it came from Netgear we figured it was ready already.
Message 3 of 6
clewis
Well, that bad drive which has been replaced now shows as type "unknown" ... but health is still "degraded" and it appears it hasn't started rebuiding the filesystem.
Message 4 of 6
mdgm-ntgr
Have you tried removing the new drive then putting it back in again?
Message 5 of 6
clewis
Yes, tried that also. The green LED lights when the drive is inserted, but it shows no activity flickers like the other drives do.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1953 views
  • 0 kudos
  • 2 in conversation
Announcements
