RichWilson's avatar
Sep 01, 2019
ReadyNAS 426 - increasing capacity to existing full unit
I have the ReadyNAS 426 with 6 x 6TB drives configured with X-Raid Raid 5.  I currently am at 79\80% capacity
I have replaced one drive with a 10TB capacity.  The unity resynced and the drives are working and showing in the interface.
I however have no additonal space.  The log after resyncing shows 80% capacity.
My intent is to quarterly add a new 10 TB drive until all 6 are replaced.
Is there something else I must do to see the extra capacity. Or is there another more appropriate approach?
  • When you are on XRAID mode and added 1st HDD of 10TB , There will be no additional capacity seen after Sync . Volume should be same around 27T even now . Space increase will be seen from the next drive added . Add the next 10TB , You should see a 3.6T increase in Space (Approx 30.5T) and the same will follow for the rest drives when repalced . This would happen only when the XRAID is on .
  • anna_arun's avatar
    anna_arun
    NETGEAR Expert
    • StephenB's avatar
      The capacity rule is "sum the disks and subtract the largest".  That gives you the size in TB; anna_arun is giving you the volume size in TiB (which is what the NAS reports).  1 TB is about .909 TiB.
    • RichWilson's avatar
      RichWilson
      Tutor
      Thanks. So I put the 2nd 10TB drive into the RN426 and after it synced the space increased.
      I moved the previous 6TB drivesn in to my RN214 that was 4x2TB.  I put them in one at a time, and synced between.  The second drive/synced just finished and no addtional space.  Showing 5. 44TB.
      This is small enough I could move the data and preprovision.  Is that my only option?
        RichWilson
        Tutor
        I found my problem.  IT was on flex raid not x-raid.  switched, and it's fine now.
ProSupport for Business
