× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAS Error Code 15002020814 - Invalid masquerade address
juraj_balaz
Hi,
neeed to help with this problem:
when I try to switch on or off Services (SMB, FTP, Antivirzs, Rsync, etc.) in SETTINGS menu, NAS always show error message and service status did not change. ReadyNAS RN10400 Firmware 6.9.3
Error message:
Service operation failed
Invalid masquerade address.
Code 15002020814
Thanks a lot for help.
Model: RN10400|ReadyNAS 100 Series 4-Bay (Diskless)
Message 1 of 4
Accepted Solutions
Guru
Re: ReadyNAS Error Code 15002020814 - Invalid masquerade address
The masquerade address is set in the FTP server settings.  Can you try clearing that field and see if the error disappears?
Message 2 of 4
All Replies
Guru
Message 2 of 4
juraj_balaz
Hi StephenB,
thanks a lot, change the settings in FTP service solved my problem.
But the major problem was, that i was change the name of NAS and in the FTP settings was enabled masquerade address with old name of NAS. This is silly, because if the masquerade address must be still same as name of NAS it would be better, that this settings will automaticaly change witch the modifiing of NAS name. And the second funny thing is, why the error message is displayed when i want change other services then FTP. Nevermind.
Once more thanks.
Message 3 of 4
Guru
The masquerade address should only be set if you want remote access with FTP.  Even there, several clients don't need it (including FileZilla).
If you don't need it, it's best to not specify one.
if you do need it, it is set to the external IP address (e.g., your router's WAN address).  Normally that would be done by entering the DDNS name for your router,not the hostname for your NAS.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1111 views
  • 1 kudo
  • 2 in conversation
Announcements
