GJSchaller
Jan 09, 2020Guide
ReadyNAS OS 6.10.2 not recognizing Time Machine backup size
While checking my ReadyNAS settings, I noticed that it listed the backup space used by Time Machine as 0 for two of my three Macs in our household. Both of those Macs are on macOS 10.15 (Catalina) - the one that lists disk usage has not been upgraded yet. (Image attached.)
I believe this may be related to the fact that Apple renamed the backup file / folder from .sparsebundle to .backupbundle, as noted here - I can confirm the file rename by using SSH to inspect the /data/.timemachine directory, and there is definately data there, even if it's not listed on the WebUI.
Any chance that ReadyNAS OS can be updated to support the new file name / extension for Time Machine backups?
Hi GJSchaller,
A fix for this issue will be included in the upcoming 6.10.3 beta firmware. There is no ETA yet on when it will be posted.
- JohnCM_SNETGEAR Employee Retired
Hi GJSchaller,
I will try simulating this on our end and will report to the appropriate team if I will get the same result.
Is your NAS running on 6.10.2 firmware?
Yes, 214. I will note older Macs still show up fine, the difference seems to be Macs on OS 10.15 (Catalina).
Sorry, - Yes, 6.10.2. 214 is my model
