× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNas 1500 no access, blank model and firmware in RAIDar
SamBInfo
Tutor
Hi there, got an old 1500 (RNRx441E-100AJS) that's not letting me access it, it's also not getting DHCP.
I've looked through the forums, and it sounds like maybe I have a corrupt file in the onboard flash?
Raidar image below:
Raidar used to show 'corrupt root' until I pulled the disks out.
Anyone got any ideas? I can telnet into it if I boot it in tech-support mode.
-Sam
Message 1 of 6
Accepted Solutions
Guru
Re: ReadyNas 1500 no access, blank model and firmware in RAIDar
It doesn't look like a flash problem to me, it appears to be disk related.  Note the NAS boots from the disks - generally from the first disk it finds.  Corrupt root can sometimes be fixed with an OS reinstall.  Though it would be good to test the disks with vendor tools (particularly disk 1).
I'd wait on the DHCP issue untill after the disk problem is resolved.
Message 2 of 6
All Replies
Guru
Message 2 of 6
Sandshark
Sensei
The lack of a model number could be from a corrupted VPD file in flash, but it's too soon to tell.  First try installing at least one drive and let it install the OS on it, as @StephenB suggested.
Message 3 of 6
SamBInfo
Tutor
Thanks very much for the advice, so far so good, it's on "Installing" and shows a model number.
Message 4 of 6
SamBInfo
Tutor
Fantastic, running and healthy.
Now I just need to find a browser that will let me connect to older ssl cypers 😕
(firefox gives SSL_ERROR_UNSUPPORTED_VERSION).
Message 5 of 6
Guru
See this:
At the end there is a setting for current firefox to allow TLS 1.0 connections.  The security implications are of course up to you to sort out.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1479 views
  • 7 kudos
  • 3 in conversation
Announcements
