- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Readynas 104 - Slow transfer speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all
Can someone please tell me if the transfer speeds i am seeing are normal. I am pretty sure that i use to see around 70Mb but now i am only seeing 10Mb, both directions.
When i transfer files from my PC to NAS or vise versa i am seeing speeds of around 10Mb, everything is on a 1G LAN so i would expect to see greater speeds than 10Mb.
My setup is
PC - Windows 10 with 1G NIC and SSD
TP Link 8port 1G switch
TP Link ADSL router with 4x1G ports
RN104 using SMB for file transfer
all cat5e cabling throughout.
My ADSL link out to the network is 10Mb, to me it looks like when i am transfering files on my LAN the transfer is going out on the internet and back again, is this possible.
Any help would be greatly appreciated.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I have managed to solve the issue, it looked to be an issue with my RJ45 terminations. I put a cable tester on each end and the pinouts where terminated incorrectly using only 6 pins out of 8. This was giving me 100Mb connection. I then re-terminated the connections and tested and the interfaces are now showing 1Gb connection with all 8 pins being used.
Thanks
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re : Readynas 104 - Slow transfer speeds
Hello just creating my forum account to ask the EXACLY same question.
My Speed a lmitited to 10 mo/s up and down since 6.6 update.
I'am actualy running 6.6.1 on RN104
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is your NAS reporting that it has a 1000Mbit (Gigabit) connection or a 100Mbit one?
- Mark as New
- Bookmark
- Subscribe
- Permalink
nas interface say 100 Mbps !!
what to do ?
EDIT : ok just change port from eth0 to eth1 and my nas card running 1 gbps.
Have ~20 Mo/s upload and ~35 Mo/s download as i had before 6.6.0 upgrade.
🙂 is there any way top improve the speed alittle more ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Nas is connected to the 1G port and NAS reports 1G connection too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is readycloud installed on the PC? If so, try disabling the Leaf VPN adapter and see if anything changes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since you did negotiate the wrong speed at least once, perhaps try a different ethernet cable (or router/switch port). The cable should be at least Cat5e.
It should be possible to get 70 MB/s download and ~35 MB/s upload with RAID-5.
Do you recall what firmware was installed when you first purchased the NAS? There have been adjustments to the low-level volume settings over time. If your volume is very old, starting fresh with a factory reset (restoring data from backup) might improve performance. I did that last spring with my RN102, and it jumped from about 35 MB/s download to 70.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No i do not have readycloud installed, and i factory reset my nas around 6 months ago after installing brand new HDD's. I am running the latest firmware. I purchased my NAS in 2014 and have alway upgraded to the latest firmware when released.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, so that is covered. Perhaps try a different cable then.
How are you testing performance? Generally I recommend NAStester (if you run windows) - http://www.808.dk/?code-csharp-nas-performance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
All cabling is new and using cat5e. When i transfer a file from my nas to my PC i can see the speed runs at around 10Mb.
When transferring files to and from a NAS drive that is all on the same LAN, do the packets leave the LAN go over internet and come back again. Because its odd that the bottle neck seems to be my broadband speed. Also when i disconnect the ADSL cable from my router my understanding is that i should still be able to connect to the NAS on its private IP as its all on the same LAN. This is not the case though the NAS loses its IP when i remove the link to the internet, is this normal?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No it shouldn't. SMB connects locally unless you have a VPN client running (which you don't).
No it's not. Can you explain your network setup a bit more?
- Are you using an ADSL gateway, or an ADSL modem + a router?
- If you are using an ADSL modem + a router, is the ethernet cable between them connected to the router's internet port?
- What brand/models are you using for internet access?
- Mark as New
- Bookmark
- Subscribe
- Permalink
can i create a new raid array without loosing data ? i dont have any storage with enought space ..?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bad connections in the cable can also completely destroy auto-negotiation (depending on what pins they are). It's good you found that problem.
