lundmilo
Apr 25, 2017Luminary
Remote access from Macbook
My daughter has moved out but would like to be able to continue to store files on my ReadyNAS using her Macbook Pro.
I am not a Mac prson my self, so I have no idea how to give her access to the files she already has stored on the unit.
Can I use ReadyCloud, and how do I do?
- jak0lantashMentor
You can use ReadyCLOUD. For more information on how to use it, you can refer to the following article: https://kb.netgear.com/22783/What-is-ReadyCLOUD-and-how-do-I-use-it-with-my-ReadyNAS-OS-6-storage-system
- lundmiloLuminary
jak0lantash wrote:You can use ReadyCLOUD. For more information on how to use it, you can refer to the following article: https://kb.netgear.com/22783/What-is-ReadyCLOUD-and-how-do-I-use-it-with-my-ReadyNAS-OS-6-storage-system
Thanks. I has tried to do that but could not find a way to share to folder holding her data.
It seems like it is not possible to share a sub folder, so I had to move the data to a seperate share.
- jak0lantashMentorAfaik, this is indeed the way.
