leew87
Mar 24, 2016Aspirant
Removing Bonded Network adaptors Readynas 104
hi
i wonder if anyone can help me i tried setting up VPN addon but had trouble so i removed it and going to do this using other harder
when i try to remove bonded ethernet altho i get the delete button when it connects to the admin page again the bonded adapter still remains
i am looking for a way i can remove this so i have two ethernet adapter showing again
thanks in advance
i am running the latest firmware 6.4.2
1 Reply
- JennCNETGEAR Employee Retired
Hello leew87.
Are the LAN cables still connected when you delete the bonded adapter?
To delete a bonded adapter and reestablish separate Ethernet links:
- Select Network > Bonds.
- Select the settings gear icon for the bonded adapter that you want to delete.
- From the pop-up menu that displays, select Delete.
Confirm the deletion.
The bonded Ethernet interfaces are separated into individual links.
- Reconfigure the switch or router to which the ReadyNAS is attached for single interfaces.
